May 20, 2025, 12:34:42 PM
2N3904 experiment
Started by saturated, May 02, 2025, 01:36:53 PM
saturated
Some eye opening results after some transistor testing  :tu:
I needed two NPN transistors
-one with lower beta/hFE than 2n3904 (hFE 173)
- one with higher
So I started testing and the first victim mps222A tested hFE 175  :grr
So next I pull out this billy badass radio shack TO-220 TIP 3055.  I'm like oh hell yeah it's on now  8|
It tested 11 hFE.  :grr  retested and got 12  :loco
Tested ecg128 and get a 171....ok keep going  xP
So I had about ten of these puny 2n3391a and wow  8| tested hFE 419  :loco
Now obviously I'm lacking comprehension here I'm sure there is a reason for this and it should make sense.
Anyhow I have my test candidates  :tu:
I ask stupid questions
and make stupid mistakes
saturated
And the results are in with some conclusions
When a small hFE transistor was placed in the circuit the voltage drop across the collector resistor was very small or very low collector current
When a large hFE transistor was placed in circuit there was a big voltage drop across the collector resistor ie much greater collector current
Meanwhile...base current remained pretty much constant
So I'm thinking that the base is like a rock.  In response to that I was gonna post Bob Seger like a rock...but I really like fire lake.
(I've been to Cold Lake but not Fire Lake)
Vbe looks "like a rock" because it is being force fed throughn am high-ish resistor (100K)
As of the wide Hfe disparity:
small signal (preamp) transistors are optimized for high gain, they don´t worry about high current because they typically will be used around 1-2 mA or so.
Low dissipation also, 300-500mW (tops).
Power transistors on the contrary are optimized for POWER  :trouble   , high dissipation (70 to 120W), high current (think 10-15 Amperes), etc.
*Everything* in this World is a compromise, so the heavy price paid is abysmal Hfe.
You will find than in all power Amps, power transistors are never used by themselves, *always* driven by a medium power driver transistor, in a Darlington or Quasi Darlington configuration, so their Hfe multiply.
For example my rule of thumb for 50-100W power amps I design is a 2N3055 (Hfe 10 @ 10A) driven by a TIP 31/32 (Hfe 40 @ 1A)) for a combined Hfe of 400, go figure.
I am very conservative (which is safe), in practice combined Hfe is quite higher, but that is a guaranteed minimum value.
Later I switched to power Darlingtons, TIP142/147 (which are a sort of Industry Standard, being also used by Fender Marshall Ampeg Laney Peavey Crate, H&Kettner which should mean something.
Guaranteed Hfe @ 10A is 1000, go figure.
saturated
Thank you very much sir that was awesome  :dbtu:
saturated
I know right now (I think) that all of this is gonna go together like a big 🗝� key lime pie I'm lust learning how to make the crust and missing the key ingredients  :tu:
saturated
Ok thought I would wrap this one up.  Last set of experiments were same setup only now an emitter resistor was added.
This was the first time I couldn't notice a trend maybe I should compare with the other configurations idk I'm still like a mindless zombie doing this stuff.
Anyhow wow an emitter with a resistor wiped out the tpi3055
Ok I did notice something seems this was the first time base current took a hit.   xP
