Solid State Amplifiers => The Newcomer's Forum => Topic started by: Den. on June 25, 2016, 06:03:52 PM
Title: Can someone help me with this test question?
Post by: Den. on June 25, 2016, 06:03:52 PM
I had this TRUE or FALSE question on a written test recently: You can change the resistance in a circuit that uses a 520ohm 1w resistor to 608ohms by adding four 22ohm 1/4w resistors in series to the existing 520ohm resistor.
I answered true but now I'm not sure of my answer.
Title: Re: Can someone help me with this test question?
Post by: phatt on June 25, 2016, 09:34:36 PM
22 div by 4 = 5.5
520 plus 5.5 = 525.5
does that help?
Post by: J M Fahey on June 25, 2016, 09:53:42 PM
Sorry Phil, unless stated otherwise they are *all*  in series so 520 + (4*22) = 520+88 = 608 .
I don´t understand how Den can have doubts about this *very basic*  question .
Post by: Den. on June 25, 2016, 10:02:09 PM
Quote from: J M Fahey on June 25, 2016, 09:53:42 PM
Yes, the way I read the question it seemed that they meant all five resistors wired in series. And I calculated that that would add up to 608. But, it was the power handling aspect I was unsure of; using four 1/4w resistors when one watt is required.
Post by: phatt on June 25, 2016, 10:06:38 PM
 whoops,,, to early over here only had one coffee :-[ :duh
Post by: Enzo on June 25, 2016, 10:57:17 PM
1w was required of the 520 ohm resistor, that doesn't mean everything else will dissipate that much.
Use Ohm's Law.  1 watt from a 520 ohm resistor means about 44ma flowing through it, if my math is right.   Since the resistors are in series, and current is the same through a series circuit, I can assume each 22 ohm resistor has 44ma through it.  So calculate the dissipation of 44ma in a 22 ohm resistor.  I get about 43mw - 0.043 watts.  So 1/4w would be six times the dissipation of the resistor in this circuit.  More than enough.
Post by: Den. on June 26, 2016, 09:05:31 AM
Thank you. Might this mean then that you would be able to substitute two 29ohm with one 30ohm or maybe even just two 44ohm rated 1/4w and still be safe?
Post by: J M Fahey on June 26, 2016, 02:23:23 PM
Quote from: Den. on June 26, 2016, 09:05:31 AM
WHICH 29/30/44 ohm resistors?
This question does not make sense since it´s missing data, besides never having heard about them before, certainly not in the above questions.
Post by: Den. on June 26, 2016, 07:39:39 PM
Quote from: J M Fahey on June 26, 2016, 02:23:23 PM
Sorry, I moved off the test question and am now trying to understand substituting different numbers of resistors with their different watt handling.
Post by: J M Fahey on June 27, 2016, 08:14:27 AM
OK.
1) determine current I flowing through that circuit.
Apply Ohm´s Law.
2) power dissipated across any resistor is: P=I^2 * R
Do the Math and check whether dissipated power is less than resistor rating.
Post by: Loudthud on June 27, 2016, 03:56:00 PM
In a series circuit, the resistor with the highest resistance will have the most dissipation. Calculate the current that will result in that resistor being at it's maximum, then check that the other resistors will be at or below their rating at that current.
In a parallel circuit, the resistor with the lowest resistance will dissipate the most power. Calculate the Voltage that will result in that resistor being at it's maximum, then check that the other resistors will be at or below their rating at that Voltage.
As a practical matter, running resistors at their maximum power rating is not a good idea. If they are on a PCB, it will usually make the board turn black. The resistor or it's solder joints will fail. A resistor's power rating is based on temperature. If they are in a warm environment, they must be de-rated. You can run resistors beyond their power rating for short amounts of time as long as the resistor does not get too hot. To be conservative, don't run resistors more than about half their power rating.
Post by: Den. on June 27, 2016, 08:27:33 PM
Quote from: Loudthud on June 27, 2016, 03:56:00 PM
Thanks everyone.
