Here's something I was kicking around a while back and I'm just curious if someone has tried it. I have a Vox amplug , the headphone amp that is supposed to model the AC30.
I don't know how much it sounds like an AC30, as I don't have one... but it sounds pretty good in the headphones. I was wondering if it would work as the preamp for one of those chip amps folks around here are building? I have no idea of what the output of an amplug is compared to a preamp. No clue as if it would work.
Has anyone here tried something similar?
Never had an Amplug but I'm sure it can drive a chip amp with good results.
Try it and tell us.
Anything that drives headphones would be fine to drive a chipamp. If you do it, let us know how it sounds.
ok, sounds like a plan. I'm going to build a tiny giant as it looks like a good first project. Of course, I need to fix some of my existing gear first, and given the demands of grad school and being an involved dad, it'll be a little while.
Quote from: BigPolishJimmy on March 28, 2012, 01:14:03 PM
I hear you. Since we had our first child 5 months ago, I've found very little time for my hobbies.
cool idea , please post up results when you try this out ! i am guessing the amplug outputs something right around line level ?
i did a bass amp with the automotive version of this :
http://www.amazon.com/Pyle-PHA25-8-Inch-Channel-Amplifier/dp/B004V9G3GQ
automotive version :
http://compare.ebay.com/like/330686997632?var=lv<yp=AllFixedPriceItemTypes&var=sbar
it uses 2 tens , actual bass amp speakers (!) and i run it off of a newer zoom bass processor . really like that amp .
I used to use a millet-design hybrid for a lot of mobile amplification needs. It actually wasn't half bad for my lighter neck pickups. I haven't tried it in a few years, but I don't see how it could hurt on mild output configurations. The devil is in the details.
The joys of grandparenting - you can hand them back! ;)
The little Vox box looks fine as a pre, but you can prove the point by getting a suitable patch lead and patching its output into the Aux input of any stereo.
