February 13, 2025, 03:25:49 AM
Is it common for a PA/intercom mic preamp to use a DC adapter
Started by saturated, December 22, 2024, 03:03:15 PM
saturated
I am seeing old Dukane 🎤🎙� mic preamps and they have stuff like "24v DC input"
Wondering if there is/was a specific reason for this  xP
Maybe the answer is because it works? Idk  :tu:
Btw HAPPY HOLIDAYS 🎄 🎁
I ask stupid questions
and make stupid mistakes
Sounds like phantom power for condenser mics.  Modern stuff uses 48V for phantom.
saturated
Yes sir thanks.  Wow  :loco no I don't plan on using any mics just looking for a boat anchor to go between a tuner/cassette/CD and my boat anchor Dukane p.a./intercom amp so I can use it for something.
Some old ones I'm seeing have mic and aux inputs I think(?) the mic signal has to be boosted (?) but again I have no use for mic inputs just want the aux because when I tried connecting a tuner it "worked" but the signal was very low and hum very high.  :grr
So I'm looking at options and don't mind spending 💰 a little bit don't want to invest in trying to make essentially scrap metal useful.   xP  :lmao:
saturated
So maybe I'm discovering that signal 🚦 to noise ratio is a thing  :tu:
My latest idea is maybe putting a guitar pedal in between or preamp out from my little rage amp
At least then I will be able (perhaps) to adjust the signal 🎚� level
Quote from: saturated on December 22, 2024, 03:03:15 PMI am seeing old Dukane 🎤🎙� mic preamps and they have stuff like "24v DC input"
Main reason, it keeps the mains hum (EMF) from iron transformers out of the chassis which keeps hum interference as low as possible. A lot of pro mixing desks have outboard supply.
Phil. (Happy Crissy to all) :)
saturated
Thanks Mr Phil nice to hear from you  :dbtu:
Ok Christmas morning I think I found my "preamp"  :loco
Works pretty good I can adjust the input on the pedal then there is an adjustment on the amp
I'm not getting much break up so I'm playing long cool woman  xP
saturated
I used a few other pedals and while playing thought a few times I felt some tingling  :grr but blew it off I'm 🗝� old  xP
Later I got a meter out hooked a mini grabber to an unwound string and black anything it read about 4v ac but when I connected the black mini grabber to an actual ground it disappeared to zero
:loco
I guess it does not have a 3-prong AC plug with chassis connected to ground pin?
