Solid State Amplifiers => The Newcomer's Forum => Topic started by: saturated on May 02, 2023, 10:55:03 AM
I have read that yellow and red are pos
and blue and black are neg...
but i can not find any markings on the speakers or terminal
thanks
meanwhile I will keep looking...it sounds good to me as is idk
THANKS AGAIN FOR FIXING MY AMP!!!!!!!!!!!!!!!!!!!!!!!!!!!
Quote from: saturated on May 02, 2023, 10:55:03 AMI have read that yellow and red are pos
You are correct, that is the colour coding Peavey uses. The red dots on the speaker baskets are the + terminal. (that means one spkr in pic is wired wrong polarity)
It looks like the Blue and Yellow wires are reversed, as long as the wires are connected correct on the PCB.
Check the colour of the 2 wires that are closest to the headphone jack, directly behind the jack on the PCB.
They should be the positive wires, the 2 wires closer to the back of the amp are the negative wires.
Cheers
Mick
When you reverse that speaker that has wrong polarity, you should notice better bottom end/bass response.
thanks guys !
too funny...I was at work reading this and I was thinking man I sure dont remember any red dots or plus and minus signs...Im gonna have to go back and look when I get home!
so Im looking at the pic and plain as day...there it is...the red dot(s)
