Please login or register.
Advanced search
News:
collapse
Pages: 1 [2]   Go Down
Author Topic: How to wire tubes  (Read 7292 times)
noobiePT
  • SSGuitar Regular
  • Chip Points: 0
    • View Profile
Re: How to wire tubes
« Reply #15 on: March 08, 2008, 08:19:49 PM »
the triodes at least are, the other i never worked with but looking through the scheme looked like was right also, but cant be sure about it. anyway, just try, its not like its gonna blow up if you got it wrong(hopefully  ;D)
Logged
  • SSGuitar Admin
  • Legendary
  • Chip Points: 978
  • SSG Creator
    • View Profile
    • thatraymond.com
« Reply #16 on: March 08, 2008, 08:44:23 PM »
I'll be giving it a try in a day or so, I have a few other projects I need to finish first.
Logged
rob_nl
  • Chipper
  • Chip Points: 0
  • Rob van der H.
    • View Profile
« Reply #17 on: March 11, 2008, 11:38:38 AM »
You can find a description of nearly any tube at duncan amps. Check out this link:
http://tdsl.duncanamps.com/
theres a downloadable version of the tube library for free on his site.
Logged
  • SSGuitar Global Mod
  • Legendary
  • Chip Points: 316
    • View Profile
« Reply #18 on: June 05, 2008, 11:25:17 PM »
For these and many others check: http://www.mif.pg.gda.pl/homepages/frank/
Noval dual triodes generally go: 1,2,3,4,5,6,7,8,9= plate, grid, cathode, filament, filament, plate, grid, cathode, filament center tap (if applicable)
Logged
  • SSGuitar Admin
  • Legendary
  • Chip Points: 978
  • SSG Creator
    • View Profile
    • thatraymond.com
« Reply #19 on: June 06, 2008, 07:17:20 AM »
I forgot to post back, I got it all working - my wiring was correct.  It's very quiet, which isn't surprising considering it's only 40mw output.  I'm considering using it as a preamp.
Logged
Jack1962
  • Elite SSGuitarist
  • Chip Points: 4
    • View Profile
« Reply #20 on: June 30, 2008, 01:46:29 PM »
go to duncanamps.com and download the TDSL prog , it id's most tubes and isf you click on the last tab to the right it will give you links to data sheets r2 ties to pin 2 on the tube.
                                           Rock On
Logged
Pages: 1 [2]   Go Up
* User Info
Did you miss your activation email?
* Recent Posts
VOX Buckingham V1121 by g1
[Today at 12:56:40 AM]
Lab series L5 Amp by g1
[Today at 12:39:38 AM]
Rocktron Pro Gap fault/schematic by Kaz Kylheku
[June 19, 2013, 12:33:28 AM]
Switch pop blues by Enzo
[June 17, 2013, 07:19:53 PM]
Fenderizer (found this schematic on the net) by phatt
[June 17, 2013, 07:12:30 AM]
