Please login or register.
Advanced search
News:
collapse
Pages: [1] 2   Go Down
Author Topic: Little Rebel  (Read 13609 times)
DrBoogey
  • Chipper
  • Chip Points: 0
    • View Profile
Little Rebel
« on: March 24, 2007, 03:36:42 PM »
Hi,
here is the schematic of a cool sounding 2Watt Amp!  ;)
I built it, and its fantastic for practising at home!
Schematic:
http://rebel.massberg.org/source/schematic.pdf
Layout:
http://rebel.massberg.org/source/layout.pdf
Logged
  • SSGuitar Admin
  • Legendary
  • Chip Points: 978
  • SSG Creator
    • View Profile
    • thatraymond.com
Re: Little Rebel
« Reply #1 on: March 25, 2007, 08:03:27 AM »
Interesting using a TL072 as a preamp chip for the LM386.  Oddly enough I'm messing around with the LM386 as a preamp chip haha.  Looks like a cool amp.  Do you have any sound clips?  Or pictures of the build?
Logged
  • SSGuitar Global Mod
  • Legendary
  • Chip Points: 267
    • View Profile
Re: Little Rebel
« Reply #2 on: March 25, 2007, 09:12:51 AM »
The "Little Rebel" site http://rebel.massberg.org has some clips.
Logged
DrBoogey
  • Chipper
  • Chip Points: 0
    • View Profile
Re: Little Rebel
« Reply #3 on: March 25, 2007, 09:58:16 AM »
My own built little Rebel sound much better than the soundclips on rebel.massberg.org.
At the moment i dont have a microphon, so i cant record my amp.
(sorry for my english! ::))
I will post some pictures here later!
Logged
obelix
  • SSGuitar Regular
  • Chip Points: 0
    • View Profile
Re: Little Rebel
« Reply #4 on: September 09, 2007, 10:16:56 AM »
hey what happened to the pictures? :)
How does it sound clean?
Logged
  • SSGuitar Admin
  • Legendary
  • Chip Points: 978
  • SSG Creator
    • View Profile
    • thatraymond.com
Re: Little Rebel
« Reply #5 on: September 09, 2007, 04:00:43 PM »
I'm not sure if I know what you mean, they seem to all be there.
Logged
LJ King
  • Master SSGuitarist
  • Chip Points: 2
    • View Profile
Re: Little Rebel
« Reply #6 on: September 09, 2007, 08:15:19 PM »
Where is there? I don't see any pictures either.
Logged
  • SSGuitar Admin
  • Legendary
  • Chip Points: 978
  • SSG Creator
    • View Profile
    • thatraymond.com
Re: Little Rebel
« Reply #7 on: September 10, 2007, 07:34:39 AM »
Aren't you guys refering to the pics on the website: http://rebel.massberg.org/ ?
All six of them load fine, click on them and they get bigger.  The links for the layout and schematic also load fine.
If you were refering to pics within the thread here, I don't think there ever were any.
**edit**
I just realized you guys were refering to DrBoogey's post when he said he would post some pics of his build.  He never did as far as I know.
« Last Edit: September 10, 2007, 07:36:54 AM by joecool85 »
Logged
Klad
  • Chipper
  • Chip Points: 0
    • View Profile
Re: Little Rebel
« Reply #8 on: September 15, 2007, 08:53:50 AM »
Ok, so i want to build this amp but on the schematic it calls for a TL082 and on the layout it says TL072 so which one is, it what did you use? and does the LM386 have o be a LM386-N3 or can i use a LM386-N1?
The reason i ask is because i can get the Lm386-N1 and TL072  locally but i would have to order the other parts.
And YAY my first post.
Logged
  • Legendary
  • Chip Points: 267
    • View Profile
Re: Little Rebel
« Reply #9 on: September 15, 2007, 10:44:38 AM »
TL082 and TL072 are both FET input dual opamps with identical pinout. It doesn't matter which one you use.
What comes to LM386 I really can't say for sure. How many different models of this IC they plan to make anyway..? The datasheet lists 5 different LM386 chips and then we have the copies from other manufacturers. :grr
Anyway, the datasheet indicates that both LM386-N1 and N3 would work with the same supply voltage range. The quoted output power of N1 is lower than of N3 but those have been quoted with Vsupply of 6V and 9V respectively so comparison is quite meaningless. Perhaps some one else can shed light into this. I suggest you use the N3 version.
Logged
tekichi
  • Chipper
  • Chip Points: 0
    • View Profile
Re: Little Rebel
« Reply #10 on: January 19, 2010, 05:55:44 PM »
hi, i'd like to build this amp but it seems that the original website has been taken down. does anyone by chance have the schematics and pcb image for this?
Logged
rocklander
  • SSGuitar Apprentice
  • Chip Points: 0
    • View Profile
Re: Little Rebel
« Reply #11 on: April 28, 2012, 12:35:41 AM »
sorry for the dredge, but I'm starting to build this (btw, project file is attached.. if that is a problem, my apologies to the mods.. I"m new here :tu:).
what I don't know is the resistors need to be a certain wattage or not.
I started building it with 1/4W resistors, but the legs don't fit to the holes 'quite right' which got me wondering if I should have been using 1/2W ones (it looks like they would fit better).
the only resistor I can see which IDs a resistor wattage is the 10R from pin5 of the 2nd 386 chip.
also worth noting that the project file PCB needs reversing.. I found that after I etched mine ::)
Logged
  • Legendary
  • Chip Points: 91
    • View Profile
Re: Little Rebel
« Reply #12 on: April 28, 2012, 09:51:46 AM »
It won't make much difference 1/4 or 1/2 Watt.
Just build with what you have.
Except of course the obvious 1Watt. :tu:
Re printing backwards,,, been there before myself. :-[
I recently etched an onboard pot backwards. :lmao: Makes you mad ay?  :grr
Logged
rocklander
  • Chip Points: 0
    • View Profile
Re: Little Rebel
« Reply #13 on: April 28, 2012, 05:01:12 PM »
thought/hoped that was the case.. thanks :dbtu:
and yup.. everything else about the project seemed so "right" so I just assumed it'd be the right way round.. might do my own layout for it later on anyway and correct it there.
Logged
rocklander
  • Chip Points: 0
    • View Profile
Re: Little Rebel
« Reply #14 on: April 28, 2012, 07:45:06 PM »
oh.. one more thing.. am I right in assuming that the 1W 10R is effectively just a sort of dummy load? I don't have (and neither does my local electronics store) a 10R 1W, but they had 8R2 1W.. so if it's a dummy load then that should do, right?..
also guessing I could stick an 8 ohm speaker in there?
Logged
Pages: [1] 2   Go Up
* User Info
Did you miss your activation email?
* Recent Posts
Strauss Bass-174 transistor Amp by TechiRick
[Today at 01:02:15 AM]
randall rg100es from1988 wont power up by Enzo
[May 23, 2013, 04:18:58 PM]
Circuit changes for the Pignose 7-100 by Enzo
[May 23, 2013, 04:13:44 PM]
Pearce Gr2 Combo In Oak by tiktok
[May 23, 2013, 04:09:34 PM]
Single supply HiZ preamp to 1 Vrms out, HELP!! by mickmad
[May 23, 2013, 11:40:37 AM]
