April 25, 2024, 08:35:24 AM
Tgen - Free software - Audio Functions generator (Windows)
Started by CrisBonis, December 19, 2012, 02:23:21 PM
Kaz Kylheku
If the frequencies are integers, like 213 or 5193 cycles per second, then that means that each frequency has an even number of cycles in a one second interval.  In other words, each waveform has a period such that one second is a multiple of that period. Therefore, in a mixture of such tones, one second is a multiple of each of their periods, which makes it a  common multiple (and not necessarily the lowest common multiple). If we take a period that is a common multiple of the waveforms, and repeat that period, we get a function that is indistinguishable from a continuation of the original. Or, in other words, any phase shift of a signal by a multiple of one second is indistinguishable from the unshifted signal, if the signal contains only integral frequencies.
http://www.kylheku.com/mp1http://www.kylheku.com/diy
CrisBonis
Hi,
the new TGen 5 beta is now avaiable on my web site.  ;)
http://www.bonisaudio.com/
see 'Download Area'
Thanks again Cris.   :dbtu:
You may have already noticed, but you have "LENGHT" instead of "LENGTH" (classic two key rollover, I do it all the time).
CrisBonis
Quote from: Roly on January 29, 2013, 08:55:58 AM
Thanks Roly, fix it in V. 5.51 ;)... with ...SPAN ... ::)
CrisBonis
#35
After several tests gone wrong ... ;)... i have rewrote the code from the the latest version of TGEN, i have did some tests with this new version, maybe can be improved in some aspects, but i think that is it the right direction...
Have Fun.   :)
Download (Download Area):
CrisBonis
#37
Quote from: Roly on February 06, 2013, 01:37:49 PM
Sorry Cris, 110Mb is too fat for me.
and your max MB are...  ? :cheesy: ?
EDIT
This is "REFERENCE" ...and the sound resolution used is the minimum to get the REFERENCE attribute, and this requires a lot of space...  ::) i can make a LITE version with halved time for any samples...  ???
CrisBonis
CrisBonis
Wow, THANKS!!!  :o
Will download and try it.
Looks like the answer to my prayers  :dbtu: :dbtu: :dbtu:
CrisBonis
Quote from: J M Fahey on February 11, 2013, 07:05:17 AM
Wow, THANKS!!!  :o
thanks to ... JM for the initial support @ Roly for testing some beta's  ;)
