WOW !!!Thanks for the 1/3 octave swept tones, covering the guitar speaker band !!!!I'll download and test it tonight !!!Thanks again.
Are these freq ISO? If so label as?{Random thought, alternate window for musical note selection?}The Custom wave is inspired! Opens the door to all sorts of different waveforms, arbitrary, pre recorded, or software generated. I'd suggest at least Audacity compatibility since that is also freeware. {There may be better, but the .WAV format is easy to write. Buried in a pile of old HDD's is a QBasic prog I wrote that generated .WAV files from whatever.}Blue sky...Have you thought of condensing the top level screen by using drop-down selections in each of the main windows?Pan control, L, R, and Slider (& toggling L-R for each scan?).ed2ad> Single sine/sq/saw/etc selection switch common to all non-co-incident functions (save interface space/complexity).Start other software buttons/options, preset for resident mixer (to manage soundcard channels/levels), and e.g. Irfanview as a player, Audacity, whatever/user set?
Quote from: Roly on January 05, 2013, 11:54:34 AMAre these freq ISO? If so label as?{Random thought, alternate window for musical note selection?}The Custom wave is inspired! Opens the door to all sorts of different waveforms, arbitrary, pre recorded, or software generated. I'd suggest at least Audacity compatibility since that is also freeware. {There may be better, but the .WAV format is easy to write. Buried in a pile of old HDD's is a QBasic prog I wrote that generated .WAV files from whatever.}Blue sky...Have you thought of condensing the top level screen by using drop-down selections in each of the main windows?Pan control, L, R, and Slider (& toggling L-R for each scan?).ed2ad> Single sine/sq/saw/etc selection switch common to all non-co-incident functions (save interface space/complexity).Start other software buttons/options, preset for resident mixer (to manage soundcard channels/levels), and e.g. Irfanview as a player, Audacity, whatever/user set?I have stolen the frequency values from my analogic audio analyzer ....have you a ISO table ?I misunderstood your question? the top menu ...yes i have considered... but for now is to easy to designing for me (is to fast, my GUI is made by hand..... argh...) PAN and the slider settings..I still have to work on these...Thanks for other things...
MSG Multi Sig Gen v0.8Unpacked okayTried to run and got "OpenAL32.dll not valid Windows image" againStarted anywaySlight leading glitch after changing settings; e.g. a tiny bit of leading square after selecting off for sine, like an audio buffer isn't being flushed after de-selection.Return to default settings button?Record One second WAV (Save As, default named from the settings)?File>Help screen didn't properly clear when closed, left residual on MSG panel.HTH
