IMPORTANT: This project is not for beginners. The voltage and current management are quite high, not counting the cost of components. For this reason you should have good knowledge and experience in electronics assembly projects of this magnitude. If you have no experience in the assembly of electronic projects, we recommend starting with a simple amplifier, such as the 40W amplifier. Otherwise any mistake can cost you money. {my emph.}
Any ideas as to why this peavey musician is screaming when it is turned on??? It stops after it's been on a few minutes.
