Please login or register.
Advanced search
News:
collapse
Pages: [1]   Go Down
Author Topic: Reducing transformer voltage  (Read 672 times)
markorock37
  • Master SSGuitarist
  • Chip Points: 1
    • View Profile
« on: June 04, 2012, 08:23:11 PM »
Building a solid state guitar amp, everything is ready to go except my rail power is too high. I'm running 52 volts and would like to get around 25-30 volts. I'm using a 36 volt power supply w center tap into a full wave rectifier and two 2200uf 50v caps. What's my best solution? Thanks
Logged
  • Legendary
  • Chip Points: 119
    • View Profile
    • Australian Valve Amps
Re: Reducing transformer voltage
« Reply #1 on: June 04, 2012, 09:23:17 PM »
Please sketch, scan and post your current power supply arrangement.  I can think of at least a couple of quite different arrangements that would fit your description.
The most obvious first thought has to be buy/scrounge/swap a more suitable transformer.
Logged
  • Legendary
  • Chip Points: 82
    • View Profile
« Reply #2 on: June 04, 2012, 10:23:45 PM »
I think so too.   I have been cleaning out the shop, and scrapping some old dead stereo recievers and stuff.  I been saving their power transformers for just such projects.  A dead smallish stereo receiver ought to provide you a reasonable transformer.  For free.
One possibility.  Is your existing transformer by any chance a 120/240v primary one?  You could probably wire the primary up for 240v operation, but feed it the 120v from the wall, and that would drop your 52v to 26v.
Logged
  • SSGuitar Global Mod
  • Legendary
  • Chip Points: 309
    • View Profile
« Reply #3 on: June 05, 2012, 12:23:51 PM »
Agree that description is not clear.
Please draw your PS as-is including voltages, polarity and whether they are AC or DC.
Logged
markorock37
  • Chip Points: 1
    • View Profile
« Reply #4 on: June 08, 2012, 06:20:21 PM »
I did find another transformer with the right voltage I can use if neccessary. But 'Ill draw up the current configuration and try to get that up here this weekend.
Logged
  • Legendary
  • Chip Points: 119
    • View Profile
« Reply #5 on: June 09, 2012, 08:38:07 PM »
There is a trick using SCR's that can be used to reduce the voltage of a transformer for a power supply (see attached).
The gate trigger voltage is obtained from a divider between the transformer peak voltage and the output voltage.  When the output voltage rises there is a point where the voltage on the gates doesn't rise high enough to trigger the SCR any more, thus limiting the output voltage.
It has a few "gotchas" however;
- at higher voltages the gates may need to be protected by diodes
- the output voltage is a function of the gate trigger voltage which is itself a function of the SCR temperature, so this simple circuit may show a high temperature sensitivity
- SCR's and audio generally don't make for good partners and there may be considerable, and objectionable, high frequency buzz in the output
Logged
Pages: [1]   Go Up
* User Info
Did you miss your activation email?
* Recent Posts
Amp cutting out, dependant on "attack" by Enzo
[Today at 03:54:26 AM]
A great find today by Bajaguy
[May 17, 2013, 11:06:52 PM]
Frontman 212R vs. Mustang IV vs. Acoustic G120 DSP vs. Behringer V-Tone GMX212 by Enzo
[May 17, 2013, 07:21:10 PM]
Bassman 400 power issue by markorock37
[May 17, 2013, 05:40:12 AM]
1970's sears 125-xl amp by Big Bruce
[May 17, 2013, 04:36:28 AM]
