Solid state sounding??? I can see 2 tubes in the back and could smell them cookin while I was playin. The tubes have covers and I was too lazy to take them off but from the size they look like 6L6.…Look, SS can't POSSIBLY sound this good and be touch sensitive and have such a smooth drive. If that is so then the tube amp Gods have been lying all along and my life's quest for tone is all for nothing.
I wonder if there are design differences between the models in this series that can explain the difference in sound between G50 and G100? It certainly sounds better.
Reminds me of a funny story that I’ve seen repeating itself a few times with different amps…QuoteSolid state sounding??? I can see 2 tubes in the back and could smell them cookin while I was playin. The tubes have covers and I was too lazy to take them off but from the size they look like 6L6.…Look, SS can't POSSIBLY sound this good and be touch sensitive and have such a smooth drive. If that is so then the tube amp Gods have been lying all along and my life's quest for tone is all for nothing.…Needless to mention, the guy who posted the quoted rants about his G100 to some forum saw two big filter caps that were sticking out of the chassis and made a mistake thinking they were tubes. If it looks like a tube amp, it sounds like a tube amp.
QuoteI wonder if there are design differences between the models in this series that can explain the difference in sound between G50 and G100? It certainly sounds better.There are. The preamp designs in series I and II are very different from another.
Few minutes with google search should however locate complete service manuals for G50 and G100, and for all three versions I, II and III too.
Yeah, but both my old G50 and this G100 are series I, single channel amps in black and silver.
I had a yamaha 2x12 combo many years ago. I forget the model but it was (something)100. It had a parametric EQ that I loved. Does the G100 have a parametric EQ?
G100-212 (not called Series I back then)These actually came in two different striped tolex colours, black and brownishG100-212 IIThese again appeared in two different striped tolex colours, same as the early one, but new features were a revised preamp with eg. parametric mid control, and in many models a dual channel setup. Even the single channel amps, G50-112II and G100-112II, still did have a revised preamp circuit. A crude short circuit proetection was also added to power amp. Note that around the time that G-series (both I and II were introduced) there were also parallel series labelled "J", "F", and "B". B was a series for bass amplifiers but the F and J series are actually very close to G-series amps. F-series amps I've seen include the parametric mid control.G100-212III - GII SeriesThis was what Yamaha labelled as the successor to G-series, the GII-series. Totally revised look no longer using the old Yamaha striped grille and with coloured knobs. The preamp design is very similar to G-series II, but as far as I know, now all models came in dual channel configuration. Power amp circuit was modified quite extensively. These amplifiers were also manufactured in USA.
I guess you saw the other G100 thread? It's a Japanses market only version of the G100 - read it online when I got mine, but can't for the life of me find the page with the info on again.
