April 26, 2024, 12:53:08 PM
Sunn Concert Lead PA
Started by gbono, August 10, 2010, 03:55:03 PM
gbono
I spent some time testing the preamp sections on this amplifier - Sunn used JFETS in the input stages of their design (Concert series). The original part is a "glob top" (preceded TO-92) package - 2N4304. I tried using Fairchild J201's and though they had the same PIN OUT and similar IDSS specifications they produced more 2nd order spurs (without change the circuit) - the PN4303 is still available and seems to give about the same results as the orginal part - FYI
I had to rebuild much of the signal path of the second channel including sourcing a new reverb pan.
Now to dial in the bias for the best distortion/power dissipation at idle.
Thanks for the help.
